OS-V: 0465 Simply-Supported Thin Square Plate
Test No. 13OptiStruct is used to investigate the repeated eigenvalues.
Figure 1. FE Model with Boundary Conditions and Loadcases
Model Files
Benchmark Model
The 2nd order and 1st order quad elements are used to model the square plate of thickness 0.05 m. The z-rotation and x, y translations are fixed for all the nodes, z-translation is fixed along all four edges, x-rotation is fixed along the edge x = 0 and x = 10 and y-rotation is fixed along the edge y = 0 and y = 10.
- Material Properties
- Value
- Young’s Modulus
- 200 x 109 N/m2
- Poisson’s Ratio
- 0.3
- Density
- 8000 kg/m3
Modal Analysis Results
f*
- Closed form solution
Mode 1 | Mode 2 and 3 | Mode 4 | |||
f* |
2.377 Hz | f* |
5.942 Hz | f* |
9.507 Hz |
HOE | 1.021926053 | HOE | 1.066977913 | HOE | 1.076061121 |
LOE | 1.013646055 | LOE | 1.015552897 | LOE | 1.053290494 |
Mode 5 and 6 | Mode 7 and 8 | ||
f* |
11.884 Hz | f* |
15.449 Hz |
HOE | 1.176750173 | HOE | 1.175007606 |
LOE | 1.002869198 | LOE | 1.065889334 |
Reference
NAFEMS R0015 - Selected benchmarks for natural frequency analysis
