OS-V: 0440 Cantilevered Tapered Membrane
Test No. FV32 A tapered membrane problem with irregular mesh. The geometry and mesh symmetry are maintained along the x-direction. The shear behavior of membrane elements in Normal Modes Analysis is examined using OptiStruct.
![fv32](../../../images/solvers/fv32.png)
Model Files
Benchmark Model
In test FV32, 4-node quad elements (CQUAD4 Lower Order Element [LOE]) with 16x8 mesh configuration are used. The taper starts with the model spanning 5.0 m in the y-direction to 1.0 m. Displacements in the z-direction are fixed on all nodes and the x- and y-translation displacements are fixed for the nodes on the 5.0 m edge along the y-axis.
- Property
- Value
- E
- 200.0 x 109 N/m2
- 0.3
- 8000.0 kg/m3
Modal Analysis Results
f*
- Closed form solution
Mode 1 | Mode 2 | Mode 3 | |||
f* =44.61
HzNormalized=1.001 |
f* =131.120
HzNormalized=1.008 |
f* =162.813
Mode 4 | Mode 5 | Mode 6 | |||
f* =250.666
f* =392.555
HzNormalized=1.033 |
f* =393.157
HzNormalized=1.004 |
Reference
NAFEMS R0015 - Selected benchmarks for natural frequency analysis
