It is assumed that the tail is cantilevered about its inboard section. Three loading
scenarios are considered; one where the tail experiences pressure loads of 0.25 psi
on the bottom skin, a second where the tail experiences a tip load of 400 lbs, and a
third where the tail experiences both the pressure load and tip load simultaneously.
The applied loading is represented below.Figure 2. Loading Experienced by Horizontal Tail Plane
The optimum design should be as light as possible without failing or buckling under
the given loading conditions.
Table 1. Part Materials
Glass_fabric
Core
Aluminum
2024-T3
E1
4Msi (4.0e6 psi)
2ksi (2000 psi)
E
10.6Msi (10.6e6 psi)
E2
6Msi (6.0e6 psi)
4ksi (4000 psi)
Nu
0.33
NU12
0.1
0.3
G
4.06Msi (4.06e6 psi)
G12
800ksi (800000 psi)
3ksi (3000 psi)
Rho
0.1 lb/in3
G1,Z
800ksi (800000 psi)
4ksi (4000 psi)
Yield
50ksi (50000 psi)
G2,Z
800ksi (800000 psi)
4ksi (4000 psi)
RHO
0.07 lb/in3
0.001074 lb/in3
Xt
35ksi (35000 psi)
500 psi
Xc
35ksi (35000 psi)
500 psi
Yt
35ksi (35000 psi)
500 psi
Yc
35ksi (35000 psi)
500 psi
S
4ksi (4000 psi)
150 psi
The optimization problem may be stated as
Objective
Minimize mass.
Constraints
Composite skins must not fail.
Aluminum ribs must not yield.
Buckling must not occur.
Design Variables
Composite ply thicknesses.
Rib thicknesses.
Launch HyperMesh and Set the OptiStruct User Profile
Launch HyperMesh.
The User Profile dialog opens.
Select OptiStruct and click
OK.
This loads the user profile. It includes the appropriate template, macro
menu, and import reader, paring down the functionality of HyperMesh to what is relevant for generating models for
OptiStruct.
Open the Model
Click File > Open > Model.
Select the tail_baseline.hm file you saved to
your working directory.
Click Open.
The tail_baseline.hm database is loaded
into the current HyperMesh session, replacing any
existing data.
Set Up the Model
Create Isotroic Materials and Properties; Assign to Metallic Ribs
Create the Material
In the Model Browser, right-click and select Create > Material from the context menu.
A default material displays in the Entity Editor.
For Name, enter al2024-t3.
Set Card Image to MAT1.
Enter the material values next to the corresponding fields.
These values are taken from the table Aluminum 2024-T3 at the
beginning of the tutorial.
For E (Young's Modulus), enter 10.6e6.
For NU, (Poisson's Ratio), enter 0.33.
For RHO (Mass Density), enter 0.1.
A new material, al2024-t3, has been created. The
material uses OptiStruct's linear isotropic material
model, MAT1.
Click Close.
Create the Property
In the Model Browser, right-click and select Create > Property from the context menu.
A default property displays in the Entity Editor.
For Name, enter Ribs.
Set Card Image to PSHELL.
Enter the property values next to the corresponding fields.
An empty Value field indicates that
it is turned off. To edit these properties, click on the blank Value fields next
to them and enter the required values.
For Material, click Unspecified > Material. In the Select Material dialog,
select a12024-t3 and click
OK.
For T (thickness of the plate), enter 1.0.
A new property, Ribs, has been created as a 2D PSHELL.
Material information is also linked to this property.
Assign Material and Property Data to the Ribs Component
In the Model Browser, right-click and select Create > Component from the context menu.
A default component template displays in the Entity Editor.
For Property, click Unspecified > Property. In the Select Property dialog, select
Ribs and click OK.
A property collector named Ribs has been created. It has a PSHELL
definition with a thickness of 1.0. It also references the Aluminum 2024-T3 material
definition and the component name Ribs.Figure 3.
Create Materials and Geometric Properties using HyperLaminate
Create Orthotropic Material Properties
From the 2D page, click the HyperLaminate panel.
HyperLaminate opens.
Create the material definition, glass_fabric.
In the Laminate Browser, right-click on MAT8 and
select New from the context menu.
A new material definition is created and appears in the Laminate
Browser under MAT8.
Under the Define, Edit material section, enter
Glass_fabric in the Material field.
Edit the following fields:
E1
4Msi (4.0e6 psi)
E2
6Msi (6.0e6 psi)
NU12
0.1
G12
800ksi (800000 psi)
G1Z
800ksi (800000 psi)
G2Z
800ksi (800000 psi)
RHO
0.07 lb/in3
Xt
35ksi (35000 psi)
Xc
35ksi (35000 psi)
Yt
35ksi (35000 psi)
Yc
35ksi (35000 psi)
S
4ksi (4000 psi)
Click Apply.
An orthotropic material definition for Glass_fabric is
complete.
Create the material definition, core.
browser under MAT8.
Core in the Material field.
E1
2ksi (2000 psi)
E2
4ksi (4000 psi)
NU12
0.3
G12
3ksi (3000 psi)
G1Z
4ksi (4000 psi)
G2Z
4ksi (4000 psi)
RHO
0.001074 lb/in3
Xt
500 psi
Xc
500 psi
Yt
500 psi
Yc
500 psi
S
150 psi
Click Apply.
Two new orthotropic material definitions have been created on the
MAT8 branch of the Laminate Browser.
Create Composite Laminates
In the Laminate Browser, right-click on PCOMP and select
A new laminate definition is created and appears in the Laminate Browser
under PCOMP.
Under the Laminate definition section, edit laminate information.
In the Name field, enter
Inboard_section_top.
Click the color box and select a new color for the laminate.
Under Stacking sequence convention, set Convection to
Symmetric-Midlayer.
Under Add/Update plies, edit ply information.
Set Material to Glass_fabric.
For Thickness T1, enter 0.25.
For Orientation (Degrees), enter 0.0.
For No. of Repetitions, enter 1.0.
Click Add New Ply three times.
Under Ply lay-up order, edit the first ply (row 1).
Set Material to Core.
For Thickness T1, enter 0.5.
For Orientation (Degrees), enter 45.
Set SOUT to YES.
Under Ply lay-up order, edit the second ply (row 2).
For Orientation (Degrees), enter 90.
Set SOUT to YES.
Under Ply lay-up order, edit the third ply (row 3).
Set SOUT to YES.
Figure 4.
Click Update Laminate.
The Inboard_section_top laminate definition is complete.Figure 5. Inboard_section Laminate
In the Laminate Browser, right-click Inboard_section_top
and select Duplicate from the context menu.
Inboard_section_btm.
Update the ply angles on the laminates Outboard_section_btm,
Outboard_section_top, Midspan_section_btm, and Midspan_section_top to be the
same as Inboard_section_top, then click Update
Laminate.
From the menu bar, click File > Exit.
HyperLaminate closes, and the laminate information is exported back to
HyperMesh.
Six laminate definitions have been created using the PCOMP
keyword.Figure 6. Laminate Definitions
Assign Newly Created Properties to the Associated Component
At this point, the model is meshed and the material and geometric properties are defined.
However, the elements are not referencing the correct property and material
information.
Edit the component, Inboard_section_top.
In the Model Browser, Component folder, select
The Entity Editor opens and displays the
component's corresponding data.
select Inboard_section_top and click
OK.
Edit the component, Inboard_section_btm.
select Inboard_section_btm and click
OK.
Arrange Elements in Respective Component Collectors
In the Model Browser, right-click on the Load
Collector folder and select Hide from the
context menu.
Edit the feature angle.
Press O on the keyboard to open the Options
panel.
Select the mesh subpanel.
In the feature angle= field, enter 37.
Click return.
This allows you to select elements by feature angle.
From the Tool page, click the organize panel.
Organize elements on the top inboard section into the Inboard_section_top
component.
Select one of the elements on the top inboard section.
Click elems > by face.
Several elements are selected on the top surface, stopping where
the angle between elements is greater than 37 degrees. The ribs elements
in between the top and bottom surface create a 90 degrees, thus the
selection set stops here.
Click dest component = and select
Click Move.
Organize the remaining elements into the correct component collectors indicated
in Figure 7.
Figure 7.
In the Model Browser, Components folder, right-click on
Tail and select Isolate Only
Only the elements forming the ribs which are in the tail collector
display.
Organize the elements forming the ribs in the Ribs component collector.
In the Organize panel, click elems > displayed.
Ribs.
Click Move.
Click return to exit the panel.
Components folder and select
Show from the context menu.
Clear empty components.
Press F2 on the
keyboard.
Set the entity selector to comps.
Click preview empty and delete
entity to clear any empty components (the tail component
in this case).
Orient Elements
From Tool page, click the normals panel.
Select the elements subpanel.
Set the entity selector to elems, then click elems > by collector.
Select Ribs.
Click comps > reverse.
Click select.
Click display.
Verify the element normals are not all in the same
direction.
If element normals are not all in the same direction, adjust element
normals.
Under orientation, set the selector to elem and
select an element whose normal is pointing inward.
Click adjust.
All skin normals should now point inwards. These skin normals are the
local z-axes for each element.
Click return to return to the main menu.
From the 2D page, click the composites panel.
Select the material orientation subpanel.
Use the comps selector to select the components that
contain all of the elements belonging to the skin.
Note: This is all components, except Ribs.
Set Material orientation method to by vector.
Under by vector, select z-axis.
Click project.
The local x-axis of each of the selected elements is oriented to be the projection of
the global z-axis. This is indicated by the small white arrows that appear on each
element.
Having defined the local x and z axes of the elements belonging to the component
collectors Inboard_section_top, Inboard_section_btm, Midspan_section_top,
Midspan_section_btm, Outboard_section_top, and Outboard_section_btm, you have fully
established the local orientation for each element referencing a composite
laminate.
Create Static and Buckling Subcases
Three loading scenarios are to be considered in this exercise: one where the tail experiences pressure loads on the bottom skin, a second where the tail experiences a tip load, and a third where the tail experiences both the pressure load and tip load simultaneously.
In previous steps, a load collector containing the pressure loads and another containing the tip load were created, but a load collector containing both together is still needed. Next is to create a load collector which is a combination of the load collectors pressure and tip_load.
Create Combination Load Collector
In the Model Browser, right-click and select Create > Load Collector from the context menu.
A default load collector displays in the Entity Editor.
In the Name field, enter Combined.
Click Color and
select a color from the color palette.
Set the Card Image to LOADADD.
For S, enter 1.0.
For LOAD_Num_Set = and enter 2.
This indicates how many load-collectors to combine.
In the Data: S1, field, click .
In the LOAD_Num_Set= dialog, edit load collector
information.
For S1(1), enter 1.0.
For L1(1), select pressure.
For S1(2), enter 1.0.
For L1(2), select tip_load.
Click Close.
A combination load collector, combining 1.0 times the loads in the pressure
load-collector with 1.0 times the loads in the tip_load collector, is created.
Create Static and Associated Buckling Subcase
From the menu bar, click View > Browsers > HyperMesh > Utility.
In the Utility tab, select FEA.
Under LoadSteps, click Buckling.
The Create Buckling Subcases opens.
Create a linear static subcase named pressure_only, which combines the pressure
loads in the load-collector pressure with the single-point constraints in the
load collector constraints, and an associated buckling eigenvalue subcase named
buck_pressure_only which calculates the first 10 buckling modes greater than 0.0
for the pressure_only static subcase.
In the Name field, enter pressure_only.
This is the user-defined name for the static subcase. If you call the
static subcase name, then the associated buckling subcase will be named
buck_name.
After the Name field, select EIGRL.
This indicates that eigenvalue analysis is to be used to calculate the
buckling modes. Currently this is the only option available.
In the V1 field, enter 0.0.
This indicates that the lower bound for the eigenvalue extraction is
0.0. This prevents negative buckling modes being calculated (negative
buckling modes indicate that buckling will occur if the loading is
reversed).
Leave the V2 field blank.
This is the upper bound for the eigenvalue extraction. You will select
a number of modes to calculate (instead of a range of eigenvalues) for
this exercise.
In the ND field, enter 10.
This requests that the 10 lowest buckling modes (which are greater
than V1) be calculated.
Set LOAD to pressure.
Set SPC to constraints.
Click Create.
Create a static subcase named tip_load_only, which combines the point loads in
the load-collector tip_load with the single point constraints in the load
collector constraints, and an associated buckling subcase which calculates the
first 10 modes greater than 0.0.
Create a static subcase named combo, which combines the loads in the
load-collector combined (that is, both pressure and tip_load) with the single
point constraints in the load collector constraints, and an associated buckling
subcase which calculates the first 10 modes greater than 0.0.
Exit the Create Buckling Subcases dialog.
Request Stress, Strain and Failure Results for Composite Laminates
Stress, strain, and failure results are not output by default for composite laminates, but
need to be requested.
Edit the property, Outboard_section_top.
In the Model Browser, Properties folder, click
properties card image.
Set FT to HILL.
This activates failure theory calculation.
For SB, enter 3,500.
This is the interlaminate shear strength of the laminate, which is the
bonding material shear strength. 3.5ksi is an assumed value, as no
material data was provided.
In the Data: MID field, click .
In the Number_of_Plies= dialog, set SOUT for all
plies to YES and click
Close.
This requests stress and strain results to be output for all
plies.
From the Analysis page, click the control cards
panel.
In the Card Image dialog, click
GLOBAL_CASE_REQUEST.
Verify CSTRAIN and
CSTRESS is selected.
Click return twice to exit the dialog.
Stress, strain, and failure results will now be output for the composite
laminates.
Submit the Job
From the Analysis page, click the OptiStruct
panel.
Figure 8. Accessing the OptiStruct Panel
Click save as.
In the Save As dialog, specify location to write the
OptiStruct model file and enter
tail_baseline_complete for filename.
For OptiStruct input decks,
.fem is the recommended extension.
Click Save.
The input file field displays the filename and location specified in the
Save As dialog.
Set the export options toggle to all.
Set the run options toggle to analysis.
Set the memory options toggle to memory default.
Click OptiStruct to launch
the OptiStruct job.
If the job is successful, new results files
should be in the directory where the tail_baseline_complete.fem was written. The tail_baseline_complete.out file is a good place to look for error messages that could help
debug the input deck if any errors are present.
View the Results
Review the Analysis Summary File
After running the OptiStruct analysis, the tail_baseline_complete.out file is written to your working directory.
This file contains a summary of the analysis run.
Using a text editor, open the tail_baseline_complete.out file.
The file contains:
A summary of the finite element model.
A summary of the optimization parameters.
Memory and disk space estimations.
Analysis results.
The Volume, Mass, and Buckling Modes for the baseline model are given in the analysis
results
section.
HyperView launches within the HyperMesh Desktop and the results are
loaded.
On the Animation toolbar, set the Animation type to (Linear).
On the Results toolbar, click to open the Contour panel.
Set the Result type to Displacement [v] and
Mag.
Click Apply.
The displacement contour displays for the 1st subcase [pressure only]. You could
also view the same for other subcases. Figure 9. Displacement Contour for pressure_only subcase.
Review Stress Results
On the Visualization toolbar, click to open the Entity Attributes panel.
Select Auto apply mode.
For Display, click Off.
This will cause any component selected, either in the display or from the list
of components, to be hidden.
Hide all of the components except the ribs.
Set the Result type to Element Stresses (2D & 3D)
[t] and von Mises.
Click Apply.
A contour plot of the von Mises stresses for the metallic ribs
displays.Figure 10.
Click Flip.
The Ribs component is now hidden and the composite laminate components
are displayed.
Set the Result type to Composite Stresses (s) and
Ply Failure.
Set Layers to 1.
Click Apply.
A contour plot of the composite failure indices from the composite skins
results is displayed for the first layer.Figure 11. Failure index for the first layer for the pressure only
loadstep After calculating the failure indices for individual plies, OptiStruct calculates the potential failure index for the
composite shell element. This is based on the premise that failure of a single
layer qualifies as failure of the composite. Thus, a failure index for composite
elements is calculated as a maximum of all computed ply and bonding failure
indices.
Note: Only plies with requested stress output are taken into account
here.
Set Layers to Max.
The maximum index for the laminate displays.Figure 12. Max failure index found on all layers for pressure only
loadstep
Repeat this process to have the maximum failure index for all loadsteps.
MAX FAILURE INDEX = 3.73 e-3 (Combo Loadstep)
Set Up the Optimization
Next you will setup the optimization problem in HyperMesh. The first step in this process is to define the
design variables. The design variables for this exercise are the rib thicknesses and
the laminates used in the composite skins.
Return to HyperMesh Desktop
HyperMesh Desktop allows you to use one HyperMesh page and multiple pages from the HyperView, HyperGraph, MotionView, and MediaView clients without having to switch
applications.
Return to HyperMesh Desktop by deleting the
HyperView page or navigating back to the
HyperMesh client.
To delete the HyperView page and return to
the HyperMesh client, click on the Page Controls
toolbar.
To keep the page open but return to the HyperMesh client page, click / in the top, right of the application
until the HyperMesh client returns.
Create and Reference a Thickness Design Variable for Metallic Ribs
From Analysis page, click the optimization panel.
Click the gauge panel.
Select the create subpanel.
Using the props selector, select the Ribs
collector.
Set the top toggle to value from property.
This sets the initial value of the design variable to be the thickness value
defined on the property card.
Toggle lower bound % to lower bound =, then enter
0.01.
This sets the lower bound for the design variable.
Toggle upper bound % to upper bound =, then enter
2.0.
This sets the upper bound for the design variable.
Set type to PSHELL - T.
Click create.
Click return twice to go to the main page.
Figure 13. Gauge Panel Settings for Rib Thickness Design Variable
Create Composite Laminate Design Variables
In the Laminate Browser, right-click on DESVAR and
A new design variable, named NewDv1, is
created.
In the Defne/Edit material section, edit the design variable.
In the Material field, enter istgf_th.
istgf_th stands for (inboard_section_top, glass_fabric, and
thickness).
In the Initial value field, enter 0.25.
In the Lower bound field, enter 0.01.
In the Upper bound field, enter 1.0.
Click Apply.
Create one more design variables named isbgf_th using the same bounds as the
istgf_th design variable.
Tip: Quickly create an identical design variable by right-clicking
on istgf_th in the Laminate Browser and selecting
Review the other ten design variables in HyperLaminate and verify their bounds
match the information in Table 2.
Table 2.
Name
Initial
Value
Lower
bound
Upper
bound
mstgf_th
0.25
0.01
1.0
msbgf_th
0.25
0.01
1.0
ostgf_th
0.25
0.01
1.0
osbgf_th
0.25
0.01
1.0
istc_th
0.5
0.01
2.0
isbc_th
0.5
0.01
2.0
mstc_th
0.5
0.01
2.0
msbc_th
0.5
0.01
2.0
ostc_th
0.5
0.01
2.0
osbc_th
0.5
0.01
2.0
Twelve total composite design variables now exist, one for the thickness of the
glass fabric for each composite laminate component, and the other for the thickness of
the core for each composite laminate component. As the laminates are symmetric, the
glass fabric will reference the same design variables on either side of the
core.
Update Composite Laminate Properties
In the Laminate Browser, under PCOMP, select
Select Optimization.
New fields appear in the Ply lay-up order table, allowing design
variables to be associated to ply thicknesses or ply orientations.
In the first row of the Ply lay-up order table, set Thickness Designvar to
istgf_th.
Now the design variable istgf_th is associated to the thickness of the
Glass_fabric material used in ply1, and, in this case, ply5 (as this is a
symmetric-midlayer type laminate) of the Inboard_section_top component
collector.
In the second row, set Thickness Designvar to
istc_th.
Now the design variable istc_th is associated to the thickness of the
Core material used in ply2 and ply4 of the Inboard_section_top component
collector.
In the third row, set Thickness Designvar to
istgf_th.
Click Update Laminate to save the design variable
assignments.
Repeat the above steps for the Inboard_section_btm composite laminate component
collector, associating the appropriate design variables.
HyperLaminate closes, and the design variable and updated laminate
information is exported back to HyperMesh.
Create Optimization Responses
From the Analysis page, click optimization.
Click Responses.
Create the mass response, which is defined for the total volume of the
model.
In the responses= field, enter mass.
Below response type, select mass.
Set regional selection to total and
no regionid.
Click create.
Create the composite failure response.
In the response= field, enter hl_ist.
Set response type: to composite failure.
Inboard_section_top collector.
Set the switch next to the props selector to
hill.
Click create.
Create the responses hl_osb, hl_ost, hl_msb, hl_mst, and hl_isb by repeating
step 4 to create optimization responses for the hill
failure criteria for the plies of the other composite laminate skins.
Create a static stress response.
In the response= field, enter vm_strs.
Set the response type to static stress.
Using the props selector, select Ribs.
Set the response selector to von mises.
Under von mises, select both surfaces.
Click create.
Create the buckling response.
In the response= field, enter buckle.
Set response type: to buckling.
In the Mode Number field, enter 1.
Click create.
The optimization response buckle, which is the lowest calculated
buckling mode for the structure, is created.
Click return to go back to the Optimization panel.
Create Constraints
In this step you will define constraints. You will attempt to minimize the total mass of
the structure, while keeping the von Mises stress in the metallic ribs below yield, the
composite failure index of the composite skins below 1.0, and the buckling modes of the
structure above 1.0.
Click the dconstraints panel.
Create the constraint, cnst1.
In the constraints= field, enter cnst1.
Click response= and select
vm_strs.
Check the box next to upper bound, then enter
50,000.
Using the loadsteps selector, select
pressure_only,
tip_load_only, and
combo.
Click create.
A constraint is defined on the von Mises stress of the metallic ribs to
be less than 50ksi for all of the static subcases.
Create the constraint, cnst2.
In the constraints= field, enter cnst2.
hl_ist.
1.0.
pressure_only,
tip_load_only, and
combo.
Click create.
A constraint is defined on the hill failure criteria for the
Inboard_section_toplaminate to be less than 1.0. for all of
Create the cnst3 through cnst7 constraints by repeating step 3.
Create the constraint, cnst8.
In the constraints= field, enter cnst8.
buckle.
Uncheck the box next to upper bound.
Check the box next to lower bound, then enter
1.0.
buck_pressure_only,
buck_tip_load_only, and
buck_combo.
Click create.
A constraint is defined on the lowest calculated buckling mode of the
structure to be greater than 1.0 for all of the linear buckling
subcases.
Click return to return to the Optimization panel.
Define the Objective Function
Click the objective panel.
Verify that min is selected.
Click response and select mass.
Click create.
Click return twice to exit the Optimization panel.
Create Additional Run Parameters
For the buckling constraint to be effectively maintained, an additional parameter needs to
be defined.
Click the opti control panel.
Select MAXBUCK=.
By default, the box preceding GBUCK= is checked
automatically.
Click return.
Together, these two options ensure that up to 10 modes are considered in the
buckling constraint.
Run the Optimization
From the Analysis page, click OptiStruct.
Click save as.
tail_opt for filename.
Click Save.
Save As dialog.
Set the run options toggle to optimization.
Click OptiStruct to run the optimization.
The following message appears in the window at the completion of the
job:
OPTIMIZATION HAS CONVERGED.
FEASIBLE DESIGN (ALL CONSTRAINTS SATISFIED).
OptiStruct also reports error messages if any exist. The
file tail_opt.out can be opened in a
text editor to find details regarding any errors. This file is written to the
same directory as the .fem file.
Click Close.
View the Results
Review the Optimization Summary File
Using a text editor, navigate to the directory where you ran the OptiStruct optimization and open the tail_opt.out file.
The tail_opt.out file contains:
An optimization iteration history.
The value of the objective, the retained constraints, and the design variables are
provided for all iterations in the optimization iteration history section.
The final iteration provides information on the mass of the optimized structure, the
values of the design variables for the optimized structure and the values of the
objective and retained constraints for the optimized structure.
Review the Iteration History
From the Page Controls toolbar, click to create a new page with the HyperView
client.
From the menu bar, click File > Open > Session.
The Open Session File window appears.
In the Open Session File dialog, navigate to the directory
the tail_opt_hist.mvw file.
This is a HyperView session which creates plots of the
objective, constraints, and design variables against iteration number using
information from the tail_opt.hist
file.
Figure 14 shows page 1 of the session, which is the plot of the
objective against iteration. It shows how the mass decreased through the
optimization process and how convergence is achieved when the change in mass levels
out.
Similar plots are available for the design variables and the constraints. There is
also a plot showing the maximum constraint violation for a given iteration against
iteration. When this value is zero, it indicates that there is no constraint
violation.Figure 14.
Compare Baseline Results with Optimized Results
From the menu bar, click File > New > Session.
A new session starts.
From the client selector, select to change the current client to HyperView.
Click Yes to continue.
From the Page Controls toolbar, change the page layout to to create a two pane view.
Figure 15.
Click the first window to activate it.
The blue halo that surrounds the window indicates that it is active.
From the Standard toolbar, click to load a new model file.
In the Load Model File dialog, navigate to the directory
where you ran the OptiStruct baseline analysis and
open the Tail_baseline_complete.h3d file.
The path and file name for
Tail_baseline_complete.h3d appears in the fields to the
right of Load model and Load results. This is good because the Hyper3D format
contains both model and results data.
Click Apply.
The model and results are loaded in the current HyperViewwindow.
Click the second window to active it.
the tail_opt_s1.h3d file.
For the optimization, analysis results are written to files named
*_s#.h3d (static analysis results, where # is the
subcase ID) and *_m#.h3d (eigenvalue analysis results,
where # is the subcase number), while the density, thickness and shape results
are written to the file *_des.h3d.
Activate the first window.
Set the Result type to Displacement (v).
Click Apply.
Activate the second window.
In the Results Browser, select subcase 1
(pressure only) load case and the last iteration.
Figure 16.
Click Apply.
A side-by-side comparison of the displacement results before the optimization
with those after the optimization displays. Notice the big change in the
value of the total displacement.
The optimized displacement results are greater than the baseline because you
were optimizing for mass without displacement constraints.Figure 17.
On the Animation toolbar, set the animation mode to (Linear static).
Click to animate the deformation. Click again to stop the
animation.
Similar steps can be followed to compare stress and composite failure plots before
and after the optimization.
Notice how the maximum value for the composite failure index is almost at the design
limit of 1.0.
Assign Thicknesses and Orientations
In this step you will import the optimum property file to assign thicknesses and
orientations.
From the client selector, select to switch to the HyperMesh client.
All result information is cleared out of the client, including all
pages. This will not affect your files on your hard drive.
From the menu bar, click File > Import > Solver Deck.
In the Import browser, click and open the tail_opt.fem file from
the directory where you ran the optimization.
Click Import.
The *.fem that the optimization was run with is
loaded into HyperMesh.
In the Import browser, click and open the tail_opt.prop file from the directory where
The tail_opt.prop file is created by OptiStruct at the end of the optimization run and
contains the optimized property data for model.
Expand the import options and select FE overwrite.
Click Import.
In HyperLaminate, review the new thicknesses assigned to the PCOMP
properties.
