Morphing
Enhancements
- Miscellaneous
 - Advanced selection can now be accessed from the guide bar for Free and Proximity tools.
Resolved Issues
- The Remesh option now appears consistently when morphing using volumes.
 - The QI legend now appears consistently when doing morphing operations with Element Check enabled after Remesh/Rebuild.
 - Constraints are now created consistently when Mapping to Geometry with the Constraint Node option activated.
 - The vector direction microdialog now appears after custom vector directions are defined.
