Geometry
New Features
- Imprint on Surface
 - Sketching now supports the Imprint on surface option for sketches drawn
                            on a parent surface geometry.
 - FE Geometry for Solid Boolean
 - Solid Boolean now supports FE Geometry for Combine, Subtract, and Intersect operations.
 - Create Polyline From Node Cloud Data
 - Creating a polyline from node cloud data is now supported under the Line Creation tool.
Enhancements
- Release Point Functionality
 - Release Point functionality has been added to the Quick Edit tools.
 - Align/Project Tool Improvements
 - The Align/Project tool has been improved for projecting on a plane for easy selection of the plane.
