Safety Report Manager
New Features
The following load cases and modules are now supported:
Seat Impact Load Cases
  • Whiplash load case for EURO-NCAP, CNCAP, FMVSS 202a, JNCAP, and KNCAP regulations.
  • Energy Dissipation and Static Headrest Test load cases for AIS 016, ART 18b, ECE R17, FMVSS 202a-5, GB 14167, and KMVSS 103 regulations.
  • Seat Belt Anchorage Description module, as part of the ECE R14 regulation.
  • Luggage Retention module, as part of the ECE R17 regulation.
  • ADR Description module for seats, as part of the ADR regulation.
  • ISOFIX module for seats, as part of the ECE R14 regulation.
Occupant Modules
EuroNCAP FAR Side Occupant Assessment, for side impact.
Enhancements
  • The Contour Plot module now supports custom legend styles and a new page for FLD.
  • A new HyperGraph default file is now supported, specifically for the Overlay functionality. Use this to control the curve legend attributes, such as visibility and legend position, when performing the Overlay process.
  • The Postscript functionality contains new option to change the line style per layer from the session files loaded in HyperGraph.
  • The Luggage Retention module can now capture animations (MP4 format) when generating a report.
  • The Loadcase Description module now accepts additional inputs for Pulse/Load and Dummy/Test equipment.
  • The Energy Dissipation module now includes a summary table for each run containing the clip 3ms and 80g values.
  • The Safety Report Manager can now either Append or Overlay the results and the slides in a PowerPoint file report during the Overlay process.
  • The Safety Report Manager supports DIAdem (*.dat) files for physical test data.
  • Time stamp information is now displayed in all animations.
Known Issues
The following known issues will be addressed in a future release:
  • Input validation check is not supported for the Battery Section Force and BOM modules.
  • The Load Path, Run Statistics, and Weld Failure modules are not supported for the Radioss and PAM-CRASH solvers.
Resolved Issues
  • For contour plots, missing layer information for Effective Plastic Strain.
  • PowerPoint slide titles are not aligned to the left.
  • In the Run Statistics summary table > Run Name field, now only the file name is displayed to avoid overflowing the cell.
