Store and Recall Views
Store a view and recall it so you can capture images from a consistent viewpoint.
Store the Current View
Store a view to recall it for future use.
In the view controls, click the Stored Views
tool.
Type a name for the view and press Enter.
Recall a Stored View
Recall a stored view to capture images from a consistent viewpoint.
tool.
Select a stored view.
Note: Custom views Draw-Top, Draw-Front, and Draw-Right are created for every operation relative to the draw direction so that you can quickly navigate between those views. They are updated automatically whenever there is a change to the draw direction.Draw-Top The view looking from the top along the draw direction Draw-Front The view from the Front The Front is decided based on the right hand coordinate system with the thumb pointing in the draw direction. The middle finger gives the direction of view from Front to Back.
Draw-Right The view from the Right
The Right is decided based on the right hand coordinate system with the thumb pointing in the draw direction. The index finger gives the direction of view from Right to Left.
