2026
New to Inspire Form? Learn the basics here.
Translate, rotate, and align parts and other objects using the Move tool and snaps.
Discover new features and enhancements in Inspire Form.
The Inspire Form workspace includes the ribbon, modeling window, legend, and status bar.
Learn how to select objects, pan and rotate the view, change the units system, and other basic tasks.
A list of supported operating systems and minimum requirements for hardware and memory.
Some ribbon tabs are associated with license features. Depending upon the tab you have invoked, additional units may be drawn. These features will be checked out for the duration of the session.
Quickly find and open the tools that are available on the ribbons.
Learn how to import geometry and export results.
Review techniques for selecting and editing objects.
Change the view in the modeling window using the mouse or view controls.
Use the Move tool to translate, rotate, and align parts and other objects.
In Free movement mode, you can use the graphic manipulators to translate and rotate objects, reposition the Move tool, align the tool to a feature, and align parts to features.
Translate objects along an axis or line, within a plane, or in 3D space.
Rotate objects around an axis.
Align objects to snap points when translating or rotating parts, pushing and pulling faces, or sketching curves.
The Systems tool is useful for aligning loads to a local coordinate system rather than the global coordinate system. Keep in mind that results are only shown in the global coordinate system.
Record a video or take a snapshot of the screen.
Change the default unit system, create custom units, and measure geometry features.
Use the Model Browser to organize your model, organize analysis and optimization objects, and access objects that aren't currently shown in the modeling window.
Learn about the forms of help and user assistance available from the product.
Modify the workspace display, default keyboard shortcuts, and other settings.
Learn keyboard shortcuts and mouse controls for common operations.
Start using Inspire Form with our interactive tutorials.
Create and assign variables to parametrize a model. This allows you to quickly iterate and compare design concepts by tweaking the values of the variables.
Create 2D sketches, surfaces, and solids.
Perform Feasibility, Blank Fit, and Blank Nesting analyses.
Use the Die Design ribbon to design and generate die surfaces.
Perform tryout analyses to validate die designs.
Evaluate designs by using geometric variables and applying a design-of-experiments (DOE) or optimization method. We recommend fully constraining your sketch when sketch variables are used in the design exploration.
Adjust the materials, environment, and properties of objects in the scene to create a photorealistic image.
Analyze the object geometry for negative draft, trim angle, and shortest distance between parts.
View the glossary or frequently asked questions.
