Move Tool
Use the Move tool to translate, rotate, and align parts and other objects.
This tool can be accessed from the Home group or by pressing M or T on your keyboard.
Drag the white planes or arrow manipulators to move selected objects, or enter a value to move them a precise distance. You can also select a plane or arrow to restrict translation or rotation to the selected plane or direction. Select the tool center to translate in 3D.
Figure 1. 1D Translation Within a Plane
Figure 2. 2D Translation Within a Plane
Figure 3. 2D Rotation Within a Plane
Figure 4. 3D Translation
Certain types of entities (like parts, concentrated masses, and forces) can be moved with the Move tool. Other entities such as sketch entities cannot be moved because their position and orientation are determined by the object to which they are applied. When a part is translated or rotated, all entities applied to the part move with it.
Microdialog Options
The Move tool's microdialog options change based on which graphic manipulator is selected.
Option Description
Align to Global Axis Align the Move tool to the global axes.
Align to Part Align the Move tool to the selected object's local axes (available only in repositioning mode, after the Move tool has been repositioned out of alignment with the object).
Show Original Position
Show the object's most recent position before it was last moved.
Reset
Restore the object to its position prior to the most recent move.
X, Y, Z Enter the distance to translate the object along the tool's axes in their respective fields.
Keyboard Shortcuts & Mouse Controls
To Do this
Activate Free movement mode M or T
Add to or remove from selection Ctrl
Reposition the Move tool Shift+drag or double-click
Exit repositioning mode Release Shift or right-click
Suspend snapping Alt
Exit tool Esc
