X-Factor
| 1 | The reference temperature. First, resistance values are computed by considering a temperature equal to 20°C. However, the user can also define his own reference
temperature to compute the corresponding phase resistance and
Line-Line resistance values. Note: This
reference temperature is used only in the winding design
environment. The test temperatures are defined in the test settings (refer to TEST chapter). |
| 2 | Setting of the “Resistance factor”. It allows adjusting the computation result of resistance with resistance measurement. Thus, the resulting phase resistance value is considered. |
| 3 | Setting of the “Inductance factor”. It allows modifying the
computation result of end-winding inductance. Thus, the resulting end-winding inductance value is considered. |
