Visualization of entities
Introduction
This section deals with the graphic representation of the modeled device.
When referring to the graphic representation of a device, we are interested:
  • on one hand, in the type of displayed view: side view, top view, bottom view, global view, … in its position and dimensions in the graphic display zone
  • on the other hand, in the different entities and their appearance: points and their visibility, lines and their color, faces, surface elements….
The first aspect of the graphic representation (called graphic view) is treated in chapter Environment and graphic representation
The second aspect of the graphic representation (called visualization of entities) is treated in this chapter.
Contents
