Command language, command files and macros
Introduction
A specific programming language is provided by Flux, which enables the automation of certain recurrent actions or the generation of new functions.
This language, named PyFlux, is a language based on the Python programming language.
By means of this language, the user can:
  • edit and run command files (scripts)
  • edit, load and run macros
Contents
