Flux e-Machine Toolbox: Tests
Running a test
run a test in FeMT by clicking on
A dialog box appears in which the user must choose the name of the test and click on
- run a test through PBS
See Run a test through PBS (by manual Export / Import) for more information
List of tests
Once the test running is done, the test appears at the bottom right. Several tests can be run on a same component, in this case they are listed:
Actions on a test
The possible actions on a test run are:
Display:
Display the test results by double-clicking on it or by right click → DisplayA tab with the name of the test is added in the central area, and it is possible to navigate easily using the filters on the left
Close:
Close the display of a test by clicking on the cross of the tab
or by right-click → CloseDelete:
Delete a test by selecting it in the list and by clicking on
or by a right-click → Delete- Export a test:
by selecting it from the list and choosing the post-process from the functions in the ribbon bar above.
- or by selecting it in the list and by clicking on
- or by a right-click on it and by selecting ni the contextual menu→ Export
by selecting the test from the list and choosing the desired export from the functions in the ribbon bar above.
or by a right-click → Quick Run
- Resume: Resume a failed test by right click → Resume
Test states
A test can have 4 states:
: the test is
successful-
the test is in progress
the test was failed or was interrupted during the Flux computation and this
test is potentially resumable
: the test is
failed and it's impossible to resume the computation
Export a test
A test can be exported in 3 different formats:
- pdf format for a report (equivalent to all the content of the central area)
- html format for a report (equivalent to all the content of the central area)
- txt format to post-process data (a text file by quantity)
- mat format to export Lookup tables for PSIM or Altair Twin Activate
software
This allows you to create a System model of your complete drive systems including power electronics and your motor that is represented by an usual speed and current control Reduced Order Model that uses Look Up Table parameters (Flux_D, Flux_Q, inductances, ...).
The mat export is available if the following two conditions are met:- The test has been computed with the MS
multi-positions or
MS-mono-position computation
modes.Note: With the TM computation mode, the mat export is not available, but it is possible to change the computation mode and choose one of the two MS computation modes: MS multi-positions or MS mono-position, then run the test again.
- The test has been run with a FeMT version greater than or equal
to 2023.0.Note: If the test was run with a version prior to 2023.0, it is possible to re-run the test with a FeMT version greater than or equal to 2023.0.
Note: With the MS multi-positions computation mode:The eddy current losses are not computed. The corresponding map is therefore not available.- For the html and pdf exports, the eddy current loss map appears black.
- For the txt export, the eddy current loss .txt file is not generated.
- For the mat export, four files are created:
- Two .mat files are created:
- A .mat file ending in "_OneRotorPos.mat" containing the lookup tables for a single rotor position: the chosen position is the one which is the closest to the one computed by the Find Rotor Angle macro. Only the two lookup tables for iron losses and eddy current losses are not exported.
- A .mat file ending in "_AllRotorPos.mat" containing the lookup tables for all rotor positions. Only the lookup table for eddy current losses is not exported.
- Two .oml files are created:
- A .oml file ending in "_OneRotorPos.oml" which allows to display in Altair Compose the lookup tables for a single rotor position: the chosen position is the one which is the closest to the one computed by the Find Rotor Angle macro. Only the two lookup tables for iron losses and eddy current losses cannot be displayed.
- A .oml file ending in "_AllRotorPos.oml" which allows to display in Altair Compose the lookup tables for all rotor positions. Only the lookup table for eddy current losses cannot be displayed.
Note: With the MS mono-position computation mode:The iron losses and the eddy current losses are not computed. The two corresponding maps are therefore not available.- For the html and pdf exports, the two maps of iron losses and eddy current losses appear black.
- For the txt export, the two . txt files of iron losses and eddy current losses are not generated.
- For the mat export, two files are created:
- A .mat file is created. It contains the lookup tables except the two lookup tables for iron losses and eddy current losses, which are not exported.
- A .oml file is created. It allows to display in Altair Compose the lookup tables except the two lookup tables for iron losses and eddy current losses, which cannot be displayed.
More details in Flux e-Machine Toolbox: Export for Twin Activate / PSIM.
multi-positions or
modes.
Resume an interrupted test
During Altair Flux e-Machine Toolbox computations, it happens that Flux fails (for example because of a lack of memory). In some cases we are able to resume it.
A test is resumable if a crash of Flux happens during the solving stage:
When a test fails and is resumable, a new error dialog is displayed, explaining that is possible to resume this test.
A failed test during Flux computations is identified with the icon
if it is
resumable.
To try to resume the test right-click on the test and choose Resume:
After clicking on “Resume” menu item, computations will restart from the last solved step.
