Steady State AC Electric: results analysis
Introduction
This section deals with the Steady state AC Electric application and answers the following question: How are results analyzed with Flux?
Post- processed quantities: about
The exploitable quantities are separated in two groups:
- local quantities, postprocessed in each point of the study domain.
- global quantities*, which result of an integration, postprocessed on the full study domain or on one part of the domain.
Note: * With symmetries and/or periodicities, quantities are computed:
- for the modelled part of the device in the finite elements domain, if the computation is done on a spatial support (region, face, volume…)
- for the full device (modelled part + no modelled part(s)), if the computation is done on an electrical component or on a mechanical set.
