Steady State AC Electric: solved equations
Introduction
In a Steady state AC Electric application the equations used for computation are:
  • the corresponding Maxwell's equations for an electrical system, and
  • the constitutive equation that characterizes the dielectric materials
The conditions of computation of a Steady state AC Electric application are the following:
  • the computation concerns the D and E fields; the B and H fields are not computed. The equations of the electric fields E, D and of the magnetic fields B, H are decoupled.
  • the fields are harmonic time dependent of the pulsation ω. In the complex form of the equations, the operator ∂/∂t is replaced by the multiplicator jω
Equations and conditions
In the previously defined conditions of computation, the equations in complex form are summarized as follows:
E : electric field strength (in V/m)
D : electric flux density (C/m2)
V : electric potential (in V)
J : current density (in A/m2)
σ : conductivity (in S)
εr : relative permittivity
ε0 : vacuum permittivity (in F/m)
Reminder about the differential operators: The curl divergence of a field is always null: div [rot (Field)] = 0.
Solved equation
The second order equation solved by the finite elements method in Flux in case of a Steady state AC Electric application is the following:
where:
  • [σ] is the tensor of the conductivity of the medium (in Siemens),
  • [εr] is the tensor of the relative permittivity of dielectric materials
  • ε0 is the vacuum permittivity; ε0 = 1/(36 π 109) (in F/m)
  • V is the electric potential (in V)
State variable
The state variable in a Steady state AC Electric application is the electric potential V (written Ve in Flux 3D). It is a complex quantity.
The uniqueness condition of the scalar field of the complex electric potential V requires that the value of this potential at least in a point of the computation domain be known.
Complex permittivity
The permittivity ε is a complex quantity that takes account of the frequency:
[ε] = [ε']- j [ε'']
where:
  • [ε'] stands for the real permittivity, and
  • [ε''] stands for the dielectric losses constant:
    [ε''] = [ε'] tan δh (with δh angle of hysteretic losses)
The second order equation solved by the finite elements method in Flux in case of a Steady State AC Electric application is the following:
