Summing or integrating the vector currents is the last step in the MoM procedure. This step leads to specific output parameters such as
far fields and impedance.
The Free Space Green Function
The free space Green's function is essential to the MoM to
allow calculation of fields at arbitrary points in 3D space. Without going into the finer
technical details of the equation, it can be stated that the Green function is contained inside
the integral operator operating on the surface currents,
Consider an infinitesimally small current element J in free
space at a point r' radiating an electric field E and a magnetic field
H.Figure 1. An infinitesimally small current element in free space at a point r’ radiating an E and
H field. Its potential at the point r is given by the Green Function.
The Green's function (Equation 2) gives the spatial response to a spatially impulsive current source. This means
that for the current element (source) located at the point r', the Green's function gives
the potential of this source at the point r, or any required point in 3D space.
with
the distance from the source to the field point. When there are
multiple of these sources distributed in space, such as over the arbitrary PEC body, the
response at the point r is given by summing all the sources (integration over all the
sources).1
1 Computational Electromagnetics for RF and Microwave Engineering, Second Edition,
David B. Davidson, p.265
