Discretizing the object or solution space is commonly referred to as meshing. It is a
necessary step to solve the integral equations.
Similar to the procedure followed to solve the charge distribution on the straight wire, the
surface of the PEC body is discretized into triangles. Therefore the currents on the triangles
are approximated as follows (similar to Equation 3):
Figure 1. The arbitrary shaped conducting body meshed into triangles.
The equation for the discretized currents can then be substituted into the EFIE (Equation 1)
to yield:
In Equation 2, the current
coefficients represented by are the only unknown quantity.
Before proceeding to the next step, it is necessary to take a closer look at basis
functions.
