Data for Wire Segments
Data for wire segments consist of data for segments and data for nodes between segments.
Wire Segments
The data for the segments follow the data for the triangles.
DATA OF THE SEGMENTS
No. label x1 in m y1 in m z1 in m nodes
medium x2 in m y2 in m z2 in m length in m radius in m
1 0 0.0000E+00 0.0000E+00 0.0000E+00 1
Free s 0.0000E+00 0.0000E+00 1.4286E-01 1.4286E-01 2.0000E-02
2 0 0.0000E+00 0.0000E+00 1.4286E-01 -1 2
Free s 0.0000E+00 0.0000E+00 2.8571E-01 1.4286E-01 2.0000E-02
3 0 0.0000E+00 0.0000E+00 2.8571E-01 -2 3
Free s 0.0000E+00 0.0000E+00 4.2857E-01 1.4286E-01 2.0000E-02
The label of the segment is given in the second column and below that the number of the medium in which the segment is located. A zero 0 means free space (vacuum). The next columns provide the coordinates of the start and end points. The numbers of the adjacent nodes are given next to the start and the end point columns in the first row for the segments. A positive sign for the node number indicates that the positive current direction is defined away from the segment and vice versa for the negative number. The length of the segment appears in the second row, followed by the radius.
Nodes between Segments
The data of the nodes between the segments is given in a data table in the output file.
DATA OF THE NODES BETWEEN THE SEGMENTS
no. of segment points of segm. info of symmetry
No. ISEGP ISEGM KNOP KNOM yz xz xy status
1 1 2 2 1 0 0 0 unknown
2 2 3 2 1 0 0 0 unknown
3 3 4 2 1 0 0 0 unknown
