Dielectric Cuboids
Data for dielectric cuboids consist of the geometry information such as the medium, label and corner points as well as the basis functions.
If dielectric volume elements (cuboids) are used, then the following data block is given in the output:
DATA OF THE DIELECTRIC CUBOIDS
No. x1 in m y1 in m z1 in m
label x2 in m y2 in m z2 in m
medium x3 in m y3 in m z3 in m
x4 in m y4 in m z4 in m
1 0.0000E+00 0.0000E+00 0.0000E+00
Cube 1.0000E-01 0.0000E+00 0.0000E+00
wood 0.0000E+00 1.0000E-01 0.0000E+00
0.0000E+00 0.0000E+00 1.0000E-01
2 0.0000E+00 0.0000E+00 1.0000E-01
Cube 1.0000E-01 0.0000E+00 1.0000E-01
wood 0.0000E+00 1.0000E-01 1.0000E-01
0.0000E+00 0.0000E+00 2.0000E-01
3 0.0000E+00 0.0000E+00 2.0000E-01
Cube 1.0000E-01 0.0000E+00 2.0000E-01
wood 0.0000E+00 1.0000E-01 2.0000E-01
0.0000E+00 0.0000E+00 3.0000E-01
Cubeand the dielectric medium with label
wood.
DATA OF THE BASIS FUNCTIONS FOR DIELECTRIC CUBOIDS
Symmetry information
No. cuboidno. direc. yz xz xy status
1 1 1 0 0 0 unknown
2 2 1 0 0 0 unknown
3 3 1 0 0 0 unknown
4 4 1 0 0 0 unknown
5 5 1 0 0 0 unknownThe first column gives the number of the basis function in consecutive numbers. The next column indicates the number of the cuboid. The column direc. indicates the direction of the basis function in the respective cuboid: the number 1 indicates that the basis function is defined from the reference point to the second corner point. The last four columns contain information regarding the symmetry properties of the cuboid where the structure and the meaning is the same as with the other basis functions.
