Data for Memory Usage
The data for the memory usage shows the number of mesh elements and basis functions which can be an indication of the memory usage.
In the table below it is also indicated how many basis functions have the status
unknown
, that is, how many basis functions have to be determined by
solving the matrix equation.
DATA FOR MEMORY USAGE
Number of metallic triangles: 0 max. triangles: MAXNDR = 176
Number of dielectric triangles: 176
Number of aperture triangles: 0
Number of RL-GO triangles: 0
Number of windscreen triangles: 0
Number of FEM surface triangles: 0
Number of modal port triangles: 0
Number of metallic segments: 0 max. segments: MAXNSEG = 0
Number of combined MoM/MTL segments: 0
Number of dielectr./magnet. cuboids: 0 max. cuboids: MAXNQUA = 0
Number of tetrahedra: 0 max. tetrahedra: MAXNTETRA = 0
Number of edges in PO region: 0 max. edges: MAXPOKA = 0
Number of wedges in PO region: 0 max. wedges: MAXPOKL = 0
Number of Fock regions: 0 max. Fock regions: MAXFOGE = 0
Number of polygonal surfaces: 0 max. surfaces: MAXPOLYF = 0
max. corner pts.: MAXPOLYP = 0
Number of UTD cylinders: 0
Number of metallic edges (MoM): 0 unknown: 0 (electr.) max. edges: MAXNKA=264
0 unknown: 0 (magnet.)
Number of metallic edges (PO): 0 unknown: 0 (electr.)
Number of dielectric edges (MoM): 264 unknown: 66 (electr.)
264 66 (magnet.)
Number of dielectric edges (PO): 0 unknown: 0 (electr.)
Number of aperture edges (MoM): 0 unknown: 0 (magnet.)
Number of edges FEM/MoM surface: 0 unknown: 0 (electr.)
0 0 (magnet.)
Number of nodes between segments: 0 unknown: 0 max. nodes: MAXNKNO = 0
Number of connection points: 0 unknown: 0 max. conn.: MAXNV = 0
Number of dielectric cuboids: 0 unknown: 0 max. cuboids: MAXNQUA = 0
Number of magnetic cuboids: 0 unknown: 0
Number of dielectric faces (VEP): 0 unknown: 0
Number of magnetic faces (VEP): 0 unknown: 0
Number of basis funct. for MoM: 528 unknown: 132 max. basisf. MAXNZEILE = 528
Number of basis funct. for PO: 0 unknown: 0 max. basisf. MAXNKAPO = 0
Note: In the above table the spacing between characters and entries was reduced to
facilitate rendering the rows as single lines of data.
