Viewing the Results
View and post-process the results in POSTFEKO.
- View the gain (in dB) of the requested far field pattern on a polar plot.
Compare the results to a similar model where the ground plane is removed.
Figure 1. The gain pattern (in dB) of the Yagi-Uda antenna with no ground, a real ground, and the optimised pattern with a real ground.
Note: Observe the effect of the ground plane on the radiation pattern.
