Adding an Optimisation Search
Add the optimisation search in CADFEKO.
- Add an optimisation search. Use the Simplex (Nelder-Mead) method and Low accuracy.
Specify the optimisation parameters.
Create optimisation mask 1 to define the upper boundary for the gain (in
dB).
- For 0° to 88°: gain
< 15 dB
- The value of 15 dB in the forward direction is selected knowing that this antenna will not be able to achieve 15 dB gain. It will not effect the optimisation.
- For 90° to 180°: gain
< -7 dB
- The value of -7 dB will have an effect on the optimisation and determines the size of the back lobes that we are willing to accept.
- Label: Mask_max
< 15 dB
Create optimisation mask 2 to define the lower boundary for the gain (in
dB).
- For 0° to 30°: gain >
8 dB
- The value of 8 dB is selected as the minimum desired main lobe gain.
- For 32° to 180°: gain
> -40 dB
- The value of -40 dB outside the main lobe is selected arbitrarily low and will not affect the optimisation.
- Label: Mask_min
8 dB
Define two far field goals. Use the H_plane far field
request to optimise the vertically polarised gain in dB (10*log[]). The weighting for both goals are equal since both
goals are of equal importance.
- Set the 1st goal to be greater than Mask_min.
- Set the 2nd goal to be less than Mask_max.
