Creating the Model
Create the model in CADFEKO. Define any ports and sources required for the model. Specify the operating frequency or frequency range for the model.
- Set the Model unit to Millimetres.
Define the following variables.
- epsr = 2.62 (The relative permittivity of the substrate.)
- patch_rad = 17.5 (The radius of the patch.)
- line_len = 79 (The length of the strip line.)
- line_width = 4.373 (The width of the strip line.)
- offset = 0 (The distance between the patch centre and the feed line.)
- substrate_d = 3.18 (The height of the substrate.)
- f_min = 2.8e9 (The minimum frequency.)
- f_max = 3.2e9 (The maximum frequency.)
Create a dielectric medium.
- Relative permittivity: epsr
- Dielectric loss tangent: 0
- Label: substrate
Create the circular patch.
Create the feed line.
Add a planar multilayer substrate (infinite plane) with a conducting layer at
the bottom.
- Add a Plane / ground.
- Select Planar multilayer substrate in the drop-down list.
- Ground plane (Layer 1): PEC
- Thickness (Layer 1): substrate_d
- Medium (Layer 1): substrate
Create a microstrip port
- Click on the short edge (beginning) of the feed line.Tip: To select the edge, hide the Plane / ground or add a cutplane.
- Add a voltage source to the port. (1 V, 0°, 50 Ω).
Set the frequency.
- Continuous (interpolated) range
- Start frequency (Hz): f_min
- End frequency (Hz): f_max
