Creating the Model
Create the model in CADFEKO. Define any ports and sources required for the model. Specify the operating frequency or frequency range for the model.
- Set the model unit to centimetres.
Define the following variables:
- freq = 1.645e9 (The operating frequency.)
- lambda = c0/freq * 100 (The wavelength in free space.)
- wa = 12.96 (The width of the waveguide.)
- wb = 6.48 (The height of the waveguide.)
- ha = 55 (The width of the horn.)
- hb = 42.8 (The height of the horn.)
- wl = 30.2 (The length of the waveguide section.)
- fl = wl - lambda/4 (The position of the feed wire in the waveguide.)
- hl = 46 (The length of the horn section.)
- pinlen = lambda / 4.56 (The length of the pin.)
Create the waveguide section.
- Delete the face coincident with the UV plane.
Create the horn section.
- Delete the face at the origin and the face opposite to that.
Create the feed pin.
- Add a wire port (segment) to the base of the line.
- Add a voltage source to the port. (1 V, 0°, 50 Ω).
- Union all parts.
- Set the frequency to freq.
