Viewing the Results
View and post-process the results in POSTFEKO.
Compare the gain (in dB) for a single patch antenna and for the 10x10 element array.
Note:
  • The single patch antenna model includes the mutual coupling between the elements as if the patch antenna is in an infinite array.
  • The gain is about 20 dB higher for the 10x10 element array than for the single element.
Figure 1. The far field gain for a single element and a 10×10 element patch array in the broadside direction.
Figure 2. The far field gain for a single element and a 10×10 element patch array in the 20° squint direction.
