Manage Custom Properties
EDEMpy allows you to read, write, modify, or delete custom properties from a deck. Unlike other EDEMpy writing functionalities, this is not limited to the last Time Step since it is used to write post-processed information back into a completed simulation.
Create a custom property using the
createCustomProperty()
function:deck.particleCustomProperties.createCustomProperty( name="Property Name", defaultValue=[0.0, 0.0, 0.0], # This would be a 3D property )
- Alternatively, if you want
defaultValue
to have the same value repeated for each dimension, the property’s dimensionality can be expressed as a number as follows:deck.particleCustomProperties.createCustomProperty( name="Property Name", defaultValue=0.0, numElements=3, # This is still a 3D property
To read a custom property, the list of existing properties available for each
property type as
customPropertyNames
is available as follows:# Returns a list of the names of all particle custom properties deck.particleCustomProperties.customPropertyNames
Get the data for a custom property as a Numpy array using the
getData()
function as follows:deck.particleCustomProperties.getData( property="Property Name", # Can alternatively use property ID tstep=0, # Timestep index particleType=0, # Must specify a particle type )
Note:The third parameter has a different meaning for each property type:- Particle: The Particle type ID
- Geometry: The Geometry ID
- Simulation: Does not have a third parameter
- Contact: Does not have a third parameter
To write a custom property, use the
setData
instead ofgetData
functions, adding a Numpy array (or list) of the desired data as an additional parameter as follows:deck.particleCustomProperties.setData( property="Property Name", # Can alternatively use property ID tstep=0, # Timestep index particleType=0, # Must specify a particle type value=[ # Assuming 3D property and 4 particles [0.1, 0.1, 0.1], [0.1, 0.1, 0.1], [0.1, 0.1, 0.1], [0.1, 0.1, 0.1], ] )
Note: Due to the multi-threaded nature of simulations, the number and ordering of particles will not be the same at each Time Step. -
To delete a custom property, use the
deleteCustomProperty
function as follows:# Can alternatively give the property ID instead of the name deck.particleCustomProperties.deleteCustomProperty("My Property")
To rename a custom property, use the
renameCustomPropertyIndex
function as follows:deck.particleCustomProperties.renameCustomPropertyIndex( prev_name, # Current name new_name # New name )
To change the order of custom properties, use the
changeCustomPropertyIndex
function as follows:deck.particleCustomProperties.changeCustomPropertyIndex( old_index, new_index )
- To get the current index of a property, use the
getPropertyIndexForName()
function as follows:deck.particleCustomProperties.getPropertyIndexForName("My Property")
The following code creates a particle custom property called
My Property
which starts as 0.0 for each particle, and increases by 1 every Time Step while the particle is in the simulation:import edempy with edempy.Deck("path_to_deck.dem") as deck: particle_type = 0 prop_name = "My Property" properties = deck.particleCustomProperties properties.createCustomProperty( prop_name, 0.0, # Default value (scalar) ) for time_id in range(1, deck.numTimesteps): # Get current values old_data = properties.getData( property=prop_name, tstep=time_id, particleType=particle_type, ) # Add 1 new_data = old_data + 1.0 # Write new values properties.setData( property=prop_name, tstep=time_id, particleType=particle_type, value=new_data )
