The example shows the name change for the Slider object from
Name changes are
also reflected in the code when the design is saved as
an OML file.
AnalysisType = uicontrol('parent', DialogRunAnalysis, 'style','slider'...
, 'max', 99 , 'min', 0 ...
, 'value', 0 , 'sliderstep', [1 10]...
, 'callbackdelay', 0 , 'orient','horizontal'...
, 'callback','AnalysisType_callback', 'interruptible','off'...
, 'enable','on'...
, 'units','normalized', 'position',[0.22 0.41 0.55 0.07]...
, 'backgroundcolor', [246 246 246]...
, 'tag','', 'tooltipstring','', 'userdata', [], 'visible','on');
