Compose-3030: Compose and OML in Batch Mode
Tutorial Level: Advanced
- Use the Compose console mode.
- Use the Compose batch mode.
- Pass input arguments to a script executed in batch mode.
- Save output to text file when running in batch mode.
Running Console Mode in Compose
In addition to the graphical, interactive mode described in previous tutorials, can also be used in Console mode. Console mode is basically a non-graphical mode that exposes, the OML command prompt in a shell.
From this prompt, all supported OML commands can be executed, with the exception of all GUI-related commands, such as plots.
To open Compose in console mode, go to .
A command window with the Compose application
running in Console mode is open as shown below:
From here, all commands (except plot-related) are available. Type any command at the prompt and press ENTER to evaluate them immediately.
You can also run a script or function file in Console mode using the
run function.
Assume a script named myscript.oml exists under D:/Test and contains these commands:
M1 = rand(5,5); disp(M1)Run this in Console mode, and check the results:
Running OML Command/Script in Console Mode
The Console mode, which is described above, can also be used by passing either commands or scripts to the application from a standard shell.
From the Windows Start menu, select Run, type
cmd and then press
ENTER.
This launches the Windows Command Prompt. Use the command prompt to run OML commands, script files or a combination of both in Compose.
At the command prompt, enter the following (replace
<installation_dir> with your actual installation
location) and press ENTER.
cd <installation_dir>\This changes the directory to the location in the installation where the Compose_Console.bat file is located.
For short help on Compose_Console.bat arguments, type the
following in the command prompt: Compose_Console.bat
–help
-e Execute the OML command then quit. -f foo.oml Load and execute the OML script called foo.oml. -help Give the list of supported optional arguments. -version Give the version of Compose. -
OML commands can be directly executed using the
–e option. Following the
Compose_Console.bat command, type –e "Any
valid OML command". For example:
Compose_Console.bat –e disp(rand(3,3))This prints a 3x3 matrix in the command prompt:
Use quotes to run multiple commands and/or commands including spaces.
OML scripts can be directly executed using the
–f option. Following the .bat
command, type –f and the path to the file
MatrixDemo.oml. This should look like the
following:
Compose_Console.bat –f <installation_dir>\tutorials\MatrixDemo.oml
Press ENTER to run the file. Notice how all the output is displayed to the command prompt. Also, the output is the same as what was displayed in Compose in the OML Command window when the script file was evaluated.
Pass an Argument to a Script
Compose_Console.bat –e input arguments –f script.omlCompose_Console.bat –e t=[0:0.1:20];initial=[0;0]; –f
<installation_dir>\tutorials\ode45_noplot.omlThe script file ode45_noplot.oml is located under <installation_dir>/tutorials/. Note that if you run the script file directly in the Compose GUI, it will prompt that variable t and initial are not defined. See the result when running the correct command in batch:
Save the Output to a File
Continue previous example, and add > output.txt at the
end of previous command:
Compose_Console.bat –e t=[0:0.1:20];initial=[0;0]; –f <installation_dir\tutorials\ode45_noplot.oml C:/output.txtAfter the –f, the paths to the two files are listed. After the two files, there is a > with another file listed. This indicates that the output from the previous files should be exported to this file. This file needs to be in a folder with write access.
Press ENTER to run the file in batch mode. This time,
there isn’t any output written to the command prompt:
Open the file output.txt in a text editor. This file
contains the output from ode45_noplot.oml script that was
run in batch mode:
Running Tcl Scripts in Batch Mode
Besides the Console mode, which is described above, Compose can be used in 'true' batch mode by just passing either commands or scripts to the application from a standard shell.
Compose also supports running scripts in full batch mode. The batch mode can be executed using the *.bat file which resides in:
<installation_dir\hwx\Compose_Batch.bat
Pass the name of the script to be executed by using the –f argument, the same as for Console mode.
Compose also supports also multiple languages. To run a Tcl script in batch, enter the following:
<installation_dir\hwx\Compose_Batch.bat –f <TCL file with .tcl extension
basic.tcl can be found in <installation_dir/tutorials/.
