Callback Functions
Learn about the callback, which is a function that is triggered when a defined action is performed on a specified GUI element.
A callback function is passed as an argument of uicontrol
, which is
then invoked to complete a user-defined routine or action.
The following example walks you through the steps to create a
pushbutton
that plots a sine curve when pressed.
Assign a
uicontrol
function to a new variable that is thebutton_handle
Define the handle of the
uipanel
as the parent object’s handle. -
Determine the
units
used asnormalized
Assign the position as
[0.02 0.05 0.2 0.05]
in normalized units. -
Define the style of the control object as
pushbutton
Define the name of the
pushbutton
with the help of the string option asPlot
Assign the callback function as
@plot_curve
. - Define the callback function that plots a sine curve and takes two arguments.
clear all; close all; clc;
global panel1;
function plot_function(handles,callback)
global slider_handle;
freq_value = 1;
t = [0:1/128:1];
x = sin(2*pi*freq_value*t);
plot(t,x);
end
f = figure('units','normalized','position',[0 0 0.9 0.9]);
panel1 = uipanel(f,'units','normalized','position',[0 0.1 0.99 0.89]);
axes('units', 'normalized', 'position', [0.2 0.15 0.7 0.7]);
button_handle = uicontrol(panel1,'style','pushbutton','units','normalized', ...
'position',[0.02 0.1 0.17 0.05],'string','Plot',...
'callback',@plot_function);
The code example produces a GUI that displays the following sin curve when the
Plot
button is clicked:
