Quick Search
Quick Search helps you find materials instantly by typing a material name, type, characterisitics, or property. SMDC suggests matching entries and supports property-based filtering using value ranges for more precise results.
You can:
  • Enter a part of material name, material type, characteristics, or property keywords. For example: DC0, Tensile Strength
  • Modify the specified search terms to include property value ranges
  • Edit the specified search text to refine your results
  1. Begin typing a search term such as material name, type, or property in the Quick Search box.
    SMDC displays real-time intelligent suggestions as you type.
  2. Choose one of the following:
    • Select one of the intelligent suggestions from the list.
    • Press Enter.
    Figure 1. Quick Search with Suggestions
    A list of matching materials is displayed.
    Figure 2. Search Result
    Note: To clear the search field, click located to the right of the search term.
  3. You can edit your search term to filter your search result.
    1. Click the Edit icon next to the search term.
    2. Update your search input and press Enter.
      Figure 3. Edit Search Term
      Search results refresh to reflect the updated input.
      Figure 4. Updated Search Results
  4. Search materials with material type to view a list of grades.
    Select one of the intelligent suggestions from the list and press Enter.
    Figure 5. Update Search with Material Type
    Figure 6. Search Result for Material Type
  5. You can update your material search with physical characteristics.
    Figure 7. Refine Search with Characteristics
    Figure 8. Updated Search Result for Material Type with Characteristics
  6. Enter material property name to find materials containing the specific property and then click Enter.
    Figure 9. Search with Material Property
  7. You can refine your search result by specifying specific property values for a material property.
    2. Enter the required material property range and press Enter.
      Figure 10. Edit Search Term Values
    Figure 11. Updated Search Results based on Property Values
