Data Edit
Administrators can preview, edit, add, delete, copy, and clone single-data, multi-data, plot data, numerical model values, and features of a material.
On the Administrator Dashboard, open Data Edit.
All available materials are listed.
Figure 1. Materials
- Select a material to view its details.
To checkout a material, click the checkbox next to the material.
The material data is checked out and you can edit the following details:
- Material, General displays the name of a material, version, dependent components, and material type details.
- Single-point data to edit all available single-point properties for a material. For example, Mechanical and Thermal properties.
- Features such as material characteristics, additives, processing, certifications, and applications can be modified.
- Plot to add new plot data and update the existing plot data for material. Click Preview to view the preview of the plot data changes you made.
- Text to add or modify the material details and its description.
- Numerical Models to add or modify the mathematical functions for deriving curves.
- Version Control provides an overview of the version history and lets you review change logs and revert to the older version.
Click
to add your comments and commit the changes to the
material.
A confirmation message Data has been committed is displayed.
