Create a Dashboard Using the Altair IoT Studio Connector
This connector enables you to retrieve the data stored in AnythingDB.
Important: To visualize data stored at the Properties-History section in
AnythingDB, or the data stored in a Category, you will first need to create an
App.
Click and create a new App by following these steps.
Note: The Application Client ID and Secret ID is required in configuring the New Workbook in Real time Visualization module. Be sure to capture and save this information.Note: The App should have Thing as Scope and the type set as Client Credentials. Don't forget to set the authorization by adding a role or some policies.
- Click .
Select a folder to work in. By default a root folder with your username has
been created. Right click to see the different operations you can perform.
- Click New Workbook.
Enter a name for the Workbook and click Create.
Add a new Data Table by clicking Workbook Data table
editor in the lower left corner.
Figure 3.
Create a Data Table by clicking the + icon.
Data tables define the queries and source data repository definitions, in order to retrieve data.
- With Data Sources highlighted, under File/URL, select Altair IoT Studio.
From the list, choose type of operation to perform:
- Get the status of all the Things from a Category
- Get properties values of a specific Thing
- Get historical values of all the properties of a specific Thing
- Manage data through HTTP
- Run a custom query
Complete the information under the Connection section:
- Space ID: from your workspace
- Client ID: from the app created in Step 1
- Client Secret: from the app created in Step 1
- Timout: Default is 10, but it can be increased
- Category name
- Thing ID
Note: The scope, Url and record path are automatically populated. A request body can be added if needed.Figure 4.
Click Generate Columns, and then click
Refresh Preview.
The columns are populated and the requested data is displayed.Tip: If something is not working as expected, click Test in the Test Connection section.
- Click Save.
Click Back to return to the Edit Dashboard view.
Figure 5.
On the blank canvas (right half section), sketch a simple square by clicking
and dragging on the blank interface.
This enables the Visualization menu.
Select the Visualization mode and configure it using the Visualization
settings.
Detailed information regarding Data Tables is available from the Panopticon Designer documentation.
