Set a Job Profile as a Default Profile
Set a profile as a default profile.
When you set a job profile as a default profile, then the default profile will be highlighted when ever you select an application pertaining to that profile.
Click the Jobs tab located in the upper left-hand of the
page.
A list of applications are displayed at the top of the Job Monitoring page.
Figure 1. List of Applications/Solvers
Double-click an application.
A job submission form is displayed.
Figure 2. Saved Job Profile
Click
below the Saved
Profiles to view the list of saved Profiles.
Figure 3. Generic Profile
Note: By default, only Generic Profile and Last Submitted profile will be listed if there are no saved profiles.The list of profiles is displayed.Figure 4. Saved Profiles List
Click Manage Profiles.
The profile management panel for the current application definition is displayed.
Figure 5. Manage Profile
Click
next to the profile.
Figure 6. Manage Profile Option
Select Make Default Profile from the menu.
Figure 7. Manage Profile - Make Default Profile
The new profile will be set as a default profile.
