Create a Job Profile
Create a job profile, a customized shortcut for submitting a job.
If you submit multiple jobs to the same application with the same arguments, it makes sense for you to create a job profile that has these arguments pre-populated for you - streamlining the process of job submission.
Click the Jobs tab located in the upper left-hand of the
page.
A list of applications are displayed at the top of the Job Monitoring page.
Figure 1. List of Applications/Solvers
Click an application.
A job submission form is displayed.
Figure 2. Job Submission Form
The following panes are displayed in the Job Submission form:- Left pane - Applications (solvers) are displayed on the left pane of the
Job Submission Form and are the applications that are installed on the
HPC complex (server) selected in the Job Submission Form. Applications
are categorized per your site's administrator.
The user defined application definition will also listed in the applications list.
- Center pane - Displays the Job Submission Form.
Tooltip displays the description of the application arguments when you mouseover the parameter field.
Profiles are displayed in a drop-down list just below the Saved Profiles. First time when you select an application, Generic Profile is selected and subsequent time Last Submitted profile is selected.
- Right pane - Displays the File Management section. You can perform all the file related activities in this section. For example, selecting a file as an input file or include files, selecting a directory as an output directory, editing a file, uploading a files, searching a file from the list.
Note: Application parameters are based on the application selected. - Left pane - Applications (solvers) are displayed on the left pane of the
Fill in the following required application parameters:
Tip: By default, only the required parameters are displayed. Move the toggle switch
to the right or click Show all
parameters next to the toggle switch to display all
available application parameters. -
Click Save this Profile.
Tip: Solver parameters that are left blank when creating a profile can later be populated when submitting a job by displaying the job submission form.The Save Profile dialog box is displayed.
Figure 3. Save Profile
Note: When you are saving the profile if the solver parameters are left blank in Job Submission form, then the Saved Profile name is suffixed with GUI while displaying the Profile name in the context menu. - Enter a profile name.
- Select the Set this as the Default profile for this application check-box to set this profile as a default profile.
Click Save.
The saved profile will be displayed in the drop-down list.
Figure 4. Saved Profile
