Settings
One button gives access to the following setting definition:
  • Thermal settings – Definition of the temperature of active components.
Only the temperature of field winding and dampers (bars and end-rings) are considered.
For more details, please refer to the document: MotorFactory_SMWF_ISP_IR_3PH_Test_Introduction – section “thermal settings”
