New thermal cooling method - Shaft cooling
A new cooling technique was implemented for all inner rotor (IR) machines currently
available at FluxMotor. The shaft-cooling feature allows users to specify a cooling
circuit that flows within the shaft section of the machine.
- The flow network modelling and coupling of the shaft-cooling with the existing thermal network of the machine makes use of the integration of Altair Flow Simulator capabilities and the solver in the backend process of FluxMotor.
- The shaft-cooling feature has an impact on the thermal and coupled solutions of
the following tests in MotorFactory area:
- Test - Characterization - Thermal - Steady State
- Test - Characterization - Thermal - Transient
- Test - Characterization - Thermal - Fitting (except for SM_WFISP_IR_3Ph Machines)
- Test - Working Point - Sine wave - Working Point I-Psi-N (for SM_PM_IR_3Ph and SM_RSM_IR_3Ph Machines)
- Test - Working Point - Sine wave - Working Point If-I-Psi-N (for SM_WFISP_IR_3Ph Machines)
- Test - Working Point - Sine wave - Working Point U-f-N (for IM_SQ_IR_3Ph Machines)
- Test - Performance mapping - Sine wave > Eff. map (for SM_PM_IR_3Ph, SM_RSM_IR_3Ph, and SM_WFISP_IR_3Ph Machines)
- The configuration follows the same workflow as the Housing - Cooling feature and
is illustrated below:
Table 1. Motor Factory – Design – Shaft – Cooling Configuration Example
1 Entry for shaft-cooling settings 2 Shaft-cooling circuit selection: - None (no shaft-cooling)
- Cooling – Hollow shaft
- Cooling – Ring shaft
3 Shaft-cooling circuit dimension settings: - Hollow shaft diameter (for hollow shaft)
- Ring inner diameter (for ring shaft)
- Ring outer diameter (for ring shaft)
When a housing design is defined by users, and the Cooling – Internal section becomes available, the shaft-cooling fluidic configuration can be defined, as illustrated below:
| 1 | Cooling circuit settings:
