A new export from FluxMotor to Siemens Simcenter Amesim
One of our big targets is to develop and export more and more machine models, like lookup table (LUT), from FluxMotor to system software.
A new area is now dedicated to exporting maps from FluxMotor to Siemens Simcenter Amesim.
| 1 | Export to external software |
| 2 | Export to external software: A new export is available to export maps to Siemens Simcenter Amesim |
| 3 | Overview to illustrate the test considered to be exported |
| 4 | User inputs to define the test conditions |
Here are the four types of export available depending on the user inputs
Here are the user inputs to perform the computations of the four packages of data.
| 1 | Standard user inputs. |
| 2 | Standard and advanced user inputs – Case to perform computations with rotor position dependency. |
| 3 | Standard and advanced user inputs – Case to perform computations without rotor position dependency. |
| 4 | Thermal inputs to perform computation with temperature dependency. |
Note: Like in the previous version, the users can also export files
dedicated to Twin Activate® or PSIMTM, the other system simulation tools, by selecting
the Export – System environment.
Warning: The new area dedicated to export LUT is available
only for synchronous machines with permanent magnets (SMPM).
