New exports of LUT to System (PSIM)
The area SYSTEM, in the EXPORT environment of Motor Factory, allows exporting data like constants, curves and maps in lookup table (LUT) formats, such as FMU and MAT format files.
Such export is now available for the wound field synchronous machine and for the reluctance synchronous machine.
The test Characterization/Model/Maps can be selected for exporting the data.
Constants, curves and maps” given in Jd-Jq plane for characterizing the 3-Phase synchronous machines with permanent magnets are computed and exported.
These files can be imported directly into environments like Altair® Activate®, Altair® Compose® or Altair® PSIM® as binary variables files (.mat) or inside block functions, ready to be integrated into schemes to represent the model of the corresponding rotating electrical machine.
In the “Test configuration” Operating quadrants to be considered can be selected. Hence, Export / System LUT (Activate or PSIM) allows exporting data based on 1, 2 or 4 quadrants.
Export / System LUT (Activate or PSIM) allows exporting data with respect to the rotor position dependency.
When selected, the rotor position dependency makes the computation done in the Jd - Jq plane with an additional fourth axis corresponding to the rotor position θr.
Area to export LUT dedicated to the reluctance synchronous machines
Motor Factory – EXPORT AREA – Export data in LUT formats available for the reluctance synchronous machines |
Area to export LUT dedicated to the wound field synchronous machines
Motor Factory – EXPORT AREA – Export data in LUT formats available for the wound field synchronous machines |
