Standard inputs
DC voltage
The voltage of the source feeding the DC machine.
Speed
The rotating speed of the DC machine.
Advanced inputs
Circuit resistance
Parasitic resistance of the circuit connecting the DC voltage source with the DC machine.
Circuit inductance
Parasitic inductance of the circuit connecting the DC voltage source with the DC machine.
Number of computations per revolution
The number of computations per revolution “No. comp. /revolution” (Number of computations per revolution) influences the accuracy of results and the computation time.
The default value is 50. The minimum allowed value is 13. This default value provides a good balance between the accuracy of results and computation time.
Number of computed revolutions
The default value is 1. The minimum allowed value is 1 and the maximum value is equal to 4.
Mesh order
The default level is second order mesh.
Airgap mesh coefficient
