Standard inputs
- Line current, rms
The line current supplied to the machine: “Line current, rms” (Line current, rms value) must be provided.
Field current
The current supplied to the field winding of the machine: “Field current” must be provided.
Control angle
Considering the vector diagram shown below, the “Control angle” is the angle between the electromotive force E and the electrical current (J) (Ψ = (E, J)).
It is an electrical angle. The default value is 45 degrees. It must be set in a range of -90 to 90 degrees.
This range of values covers all the possible working point in motor convention.
| Definition of the control angle Ψ - Motor convention |
Advanced inputs
The list of advanced inputs dedicated to this export are listed below.
Rotor initial position mode
By default, the “Rotor initial position mode” is set to “Auto”.
 - Rotor initial position
Mesh order
The default level is second order mesh.
Airgap mesh coefficient
