Properties of Arms and Antennas
Arm1
- Height (mounted): 9 m
- Material: Steel
- Length of both arms: 300 mm
- Distance between both arms: 500 mm
- Vertical tube:
- Cross section: Rectangular
- Length (Height): 1000 mm
- Width (cross-section): 50 mm
- Azimuth of arm: 180°
- Antenna 1-1:
- Azimuth: 0° (relative to arm)
- Elevation: 0°
- Phase offset: 0°
- Radome
- Type: Cuboid
- Dimension: (W x D X H): 150 mm x 50 mm x 800 mm
- Material: Steel
Arm 2
- Material: Steel
- Length of both arms: 450 mm
- Vertical tube:
- Azimuth of arm: 0°
- Antenna 2-1:
- Azimuth: 45° (relative to arm)
- Elevation: 0°
- Phase offset: 0°
- Sub-arm:
- Width: 40 mm
- Distance between mounting points: 100 mm
- Length: 50 mm
- Radome
- Type: Cuboid
- Dimensions: (W x D x H): 150 mm x 50 mm x 800 mm
- Material: Steel
- Antenna 2-2:
- Azimuth: 315° (relative to arm)
- Elevation: 0°
- Phase offset: 0°
- Sub arm:
- Width: 40 mm
- Length of sub-arms: 50 mm
- Radome
- Type: Cuboid
- Dimensions (W x D x H): 150 mm x 50 mm x 800 mm
- Material: Steel
