MASC supports antennas mounted at masts as well as antennas mounted in front of walls:Figure 1. The Definition of local environment dialog.
The following configurations are supported:
Quasi-omni (mast configuration)
Skew (mast configuration)
Side-mounted (mast configuration)
Antenna in front of a wall (wall configuration)
The difference between the first three configurations (quasi-omni, skew, and side-mounted) is
only the angle between arm and antenna. But as you can define these angles, each configuration
can be described by the mast configuration.
The Antenna in front of a wall configuration is different as the antennas are mounted
on a wall instead of a mast.
