Step 1: Definition of Configuration
The following configuration is examined (these parameters must be defined):Figure 1. Example of a mast with quasi-omni configuration
![](../../../../../images/winprop/user_guide/aman/multiple_antenna_scenario_config/mast_quasi_omni.png)
- Quasi-Omni configuration
- Number of antennas: N = 3
- 1 Antenna at first arm
- 2 Antennas together at second arm
- Diameter of the mast: 500 mm
- Height of mast: 10 m
- Material of mast: Steel
- Power splitter: Antenna 1-1 - Antenna 2-1 - Antenna 2-2 : 2:1:1
