Step 3: Computation of the Electrical Parameters
The spheroid for the computation has a radius of 1000 m. All points to be computed and all objects are inside the spheroid. The center of the spheroid is the point Mgeo.
The transmitter power of the single antennas is according to the power splitter defined
as:
- Antenna 1-1: 1.0 Watt
- Antenna 2-1: 0.5 Watt
- Antenna 2-2: 0.5 Watt
The transmitter power of isotropic radiator (used as a reference to determine the gain of the actual antenna configuration):
The antenna patterns of antenna 1-1, 2-1 and 2-2 are already in 3D, or they must be interpolated from 2x2D to 3D.
