FromModelica Function
Use the FromModelica function to define parameter values of Twin Activate Modelica components.
The FromModelica function gives you access to Modelica resources, which you can use to define the parameter values of Twin Activate Modelica components. These resources include both data and functions available in Modelica libraries, and other Twin Activate Modelica components present in the model.
FromModelica(path [,opt1 [, opt2]])
- path
- Designates either an entity in a Modelica library or a component in the model.
- opt1
- Can be a string, representing a name, specifying an entity (an element of a record, an element of a package, a component parameter…), a struct, defining a modifier, or a cell containing the arguments of a function call. A struct is also used in case of function-calls with named arguments.
- opt2
Examples
In case of Modelica library access, path
is an OML string
designating a library element following the usual Modelica syntax, where the
hierarchy is specified using “dot” notation, with “Modelica” as root in case of MSL
for example. The path can designate a constant, a record, a function, a package,
etc.
FromModelica(‘Modelica.Constants.T_zero’)
record
where M330_50A
is an
element of Package
Modelica.Magnetic.FluxTubes.Material.HysteresisEverettParameter
FromModelica('Modelica.Magnetic.FluxTubes.Material.HysteresisEverettParameter.M330_50A')
record
where the name of the record is provided
as the second argument of the function:
FromModelica('Modelica.Magnetic.FluxTubes.Material.HysteresisEverettParameter’,’M330_50A')
rec
is an OML string defined in the workspace of the
diagram containing the component, specifying the record selected in the package:
FromModelica('Modelica.Magnetic.FluxTubes.Material.HysteresisEverettParameter’, rec)
For example, rec
can be conditionally defined in the diagram context
as:
if cond, rec=’M330_50A’, else rec=’M270_50A’; end
FromModelica('Modelica.Magnetic.FundamentalWave.Types','SalientReluctance',struct('d',12, 'q',14))
The modifier above is specified by an optional argument of type OML structure. The
argument struct(‘d’,12,’q’,14)
corresponds to the Modelica
modification (q=12, q=14). Note that the new values of d
and
q
record elements can be parameterized using OML
expressions.Function calls in Modelica can be done both with and without named arguments. Named arguments can be considered specific modifiers and can be specified using OML as indicated previously. The positional argument passing is supported using a cell instead of a struct.
m=3
FromModelica('Modelica.Electrical.MultiPhase.Functions.symmetricOrientation’,struct(‘m’,3))
m
is the first (and unique) argument of the
symmetricOrientation function, the same result is obtained by
the following example:
FromModelica('Modelica.Electrical.MultiPhase.Functions.symmetricOrientation’, {3})
FromModelica('Modelica.Electrical.MultiPhase.Functions.activePower’, {v,i})
The following examples show the use of the function on components in the Diagram, especially components inside super blocks.
FromModelica('./myModelicaBlock')
FromModelica('../myModelicaBlock')
FromModelica('/myModelicaBlock')
FromModelica('./mySuperBlock/myModelicaBlock')
FromModelica('./myModelicaBlock').myVar
FromModelica('./myModelicaBlock').myArray(1)
OrFromModelica('./myModelicaBlock')(1).myVar
