Modelica Custom Block
Define components and Modelica blocks with the MoCustomComponent block.
From the Palette Browser, select block. Drag and drop the block into your diagram and double-click
it.
The block dialog appears with tabs to define the Ports, Parameters and SimFunction for the block.
- On the Ports tab, enter the number of input and output ports for the block, enter a name for each port, then click OK.
- On the Parameters tab, enter the number of parameters for the block. For each parameter, enter a name, value and type, and click OK.
- On the SimFunction tab, enter the simulation function for your block, then click OK.
