SS-T: 2050 Remote Mass
Tutorial Level: Beginner Create Remote Mass in SimSolid.
Purpose
SimSolid performs meshless structural analysis that works on full featured parts and assemblies, is tolerant of geometric imperfections, and runs in seconds to minutes. In this tutorial, you will do the following:
  • Create Remote Mass on a Gantry hoist.
Model Description
The following file is needed for this tutorial:
  • RemoteMass.ssp
The project file has the following specifications:
  • Material is set to Steel for all parts.
  • Regular connections with 0.003mm gap and penetration tolerance.
Open Project
  1. Start a new SimSolid session.
  2. In the main window toolbar, click Open Project .
  3. In the Open project file dialog, choose RemoteMass.ssp
  4. Click OK.
Create Remote Mass
  1. On the Connections workbench, select > Remote Mass.
  2. In the modeling window, select the faces as shown in orange in Figure 2.
  3. Verify the Coordinate system tab is selected and clear the Set in COG check box.
  4. Enter coordinates for where to apply the remote mass.
    1. For Origin X, enter 0.00422237.
    2. For Origin Y, enter -0.25.
    3. For Origin Z, enter 0.00197289.
  5. Set the Coordinate system.
    1. Select the Axis X radio button and enter [1, 0, 0] for [X, Y, Z].
    2. Select the Axis Y radio button and enter [0,1, 0] for [X, Y, Z].
  6. Click on the Inertia tab.
  7. For Mass, enter 25.
    Figure 3.
  8. Click OK.
    The Remote Mass is listed under Connections > Virtual Connectors in the Project Tree. It is shown in the modeling window as a point mass at the specified coordinates.
    Figure 4.
Create Modal Analysis
  1. In the main window toolbar, click Modal Analysis.
  2. In the Number of modes window, specify the number of modes as 9.
  3. Click OK.
    The new modal analysis appears in the Project Tree.
Create Immovable Support
  1. In the Analysis Workbench, select Constraints > Immovable support.
  2. In the dialog, verify the Faces radio button is selected.
  3. In the modeling window, select the face(s) highlighted in orange in the figure below.
    Figure 5.
  4. Click OK.
    The new constraint, Immovable 1, appears in the Project Tree. A visual representation of the constraint is shown on the model.
Edit Solution Settings
  1. In the Analysis branch of the Project Tree, double-click on Solution settings.
  2. In the Solution settings dialog, for Adaptation select Global+Local in the drop-down menu.
  3. Click OK.
Run Analysis
  1. In the Project Tree, open the Analysis Workbench.
  2. Click Solve.
Review Results
  1. In the , select Structural 1 subcase.
  2. In the Analysis Workbench, click Result plot > Displacement > Displacement magnitude.
    The Legend window opens and displays the contour plot.
Compare Results With and Without Remote Mass
  1. Copy Design Study 1 to create Design Study 2.
    1. In the Project Tree, right-click on Design Study 1, and then select Copy from the context menu.
  2. Under Design Study 2 > Connections, right-click on Remote mass 1, and then select Delete from the context menu.
  3. Select Design Study 2 and click (Solve) on the workbench toolbar.
  4. Plot Displacement Magnitude for Design Study 2.
    1. In the Analysis Workbench toolbar, click Results plot.
    2. Select Displacement Magnitude.
  5. In the Project Tree, click between the Results branches for both Modal analyses to compare the Displacement Magnitude plots.
    Figure 6. Results with Remote Mass
    Figure 7. Results without Remote Mass
