SS-T: 2000 Edit Connections
Tutorial Level: Beginner Edit regular connections in SimSolid.
- Purpose
- SimSolid performs meshless
structural analysis that works on full featured parts and assemblies, is
tolerant of geometric imperfections, and runs in seconds to minutes. In this
tutorial, you will do the following:
- Use the Review part connections dialog to edit regular connections.
- Model Description
- The following model file is needed for this tutorial:
- EditConnections.ssp
Open Project
- Start a new SimSolid session.
In the main window toolbar, click Open Project
- In the Open project file dialog, choose EditConnections.ssp
- Click OK.
View Connections
In the modeling window, select the parts highlighted in
orange in Figure 2.
Right-click on the selected parts and select Review part
connections in the context menu.
All connections are listed in the Review dialog under Part connections.
Figure 3.
In the Project Tree under Assembly, select the
battery.
Figure 4.
Connections between the selected parts will be listed in the Review dialog by default. You can change this by clearing the Connections between parts in list only check box. The connections here are not well established and need to be edited in the next step.
Edit Connections
In the Review dialog, select a connection and click
Edit.
Figure 5.
The Add/Edit connection dialog will open. Gap and penetration tolerances and connection resolution setting are listed.Figure 6.
In the dialog, set Gap and Penetration tolerances to
1.25mm and 0.5mm
respectively.
Figure 7.
- Click Find connections.
- Under Connections found, review the connection and click OK to accept.
When prompted to replace existing connections, click
Yes.
All existing connections between selected parts are highlighted in red in the Project Tree and in the Review dialog.
Figure 8.
- In the Review dialog, click Close.
