Import Design Study Geometry from SolidWorks
Use geometry from SolidWorks in a SimSolid design study.
Start SolidWorks and make sure the SimSolid add-in is activated.
In the SimSolid add-in tab, click the
(Open in SimSolid) button.
This will transfer the current active assembly to SimSolid.Note: You can easily mix and match between different CAD sources. One SimSolid Project can have CAD data from Onshape, SolidWorks, or any other supported CAD format.
