Compare Results
Use Fast Results Switching to compare results from different design studies.
Display an analysis result in the modeling window.
Note: You can do this from either a saved bookmark or the
(Results plot) icon on the Analysis workbench
toolbar. -
In the Project Tree choose another analysis to
display.
The modeling window will instantly update to display the new geometry and analysis results.
- Switch between analyses as quickly as you desire.
